TwinTurbo.NET: Nissan 300ZX forum - Replacing rod and main bearings...
Subject Replacing rod and main bearings...
Posted by Wright (Ca) on October 26, 2011 at 11:27 AM
  This message has been viewed 192 times.
Message This winter I will be replacing the bearings on my 185,000 mile Z. I have a couple questions for you experienced members.
1. Can all of the rod and mains hardware be re-used? If not, what should be replaced?
2. I've always been under the impression it is bad to turn a engine with hydraulic lifters upside down...can I turn it upside down at all to work on the bottom end and for how long?
3. My most recent compression test results are:
6: 155
4: 160
2: 155
5: 155
3: 145
1: 155
My question is, would it be a good idea to have the block honed, rings replaced, and heads refreshed? I don't have power goals beyond what stock turbos are capable of so I don't want to upgrade the internals right now. Should I just leave it alone?
4. Is the oil pump something I should consider replacing even if I'm not having any oil pressure issues?
Thanks
"...You can't take it with you, live life to it's fullest, love your kids and
your wife and the simple things in life....smile and laugh as often as you
can!" sawbonez September 11, 2011 at 6:11 PM
Formerly: ZEVAN (Ca), Evan3zx(ca)
