TwinTurbo.NET: Nissan 300ZX forum - Re: Anyone know if this sounds like a timing belt slip??
Subject Re: Anyone know if this sounds like a timing belt slip??
Posted by Zerosum on October 25, 2011 at 10:47 PM
  This message has been viewed 130 times.
In Reply To Anyone know if this sounds like a timing belt slip?? posted by Serg300zx on October 25, 2011 at 01:06 PM
Message Put the car to TDC and pull off the front covers and check the belt to see if the gears are all lined up. The time you have spent to diag. you could have taken off the top two timing covers, four compressor pipes and like 10 allen head bolts to check the cover and see. You don't have an upper fan shroud which helps save time.
