TwinTurbo.NET: Nissan 300ZX forum - Not all gas leaks are external. This is what I would do if I
Subject Not all gas leaks are external. This is what I would do if I
Posted by Bo (Houston) on October 25, 2011 at 10:14 PM
  This message has been viewed 168 times.
In Reply To also if its leaking gas into the cylinder it could hydrolock posted by Crim on October 25, 2011 at 06:54 PM
Message was you. First try to start the car a few times and get the fuel pressure up. If you insist that fuel is leaking in the intake check the vacuum lines going from the balance tube to the FPR and FD. In some cases that I've heard about a little gas can leak through there onto the intake manifold. Those vacuum lines should be completely dry. If your engine is getting flooded somehow there is no way it's going to start until you clean all the gas off your spark plugs, or possibly wait a day for them to dry out. So in conclusion,fully charge your battery and clean all your spark plugs, crank the engine with no plugs to clear everything out, pu the clean plugs back in and try to start to see what happens. As said above I seriously doubt your timing belt slipped out of nowhere. Injector o-rings could leak gasinto the engine too but in your case doubt that too. Do what I requested and report back and I will be happy to help you further in this investigation. Good luck dude-
Bo
