TwinTurbo.NET: Nissan 300ZX forum - Hold up..
Subject Hold up..
Posted by KongZTT GT28RS MD on October 24, 2011 at 9:26 PM
  This message has been viewed 108 times.
In Reply To Re: Check your fuel pressure. posted by booosting...... on October 24, 2011 at 11:25 AM
Message You say it idles fine if you spray starting fluid in the tb's?
How would it idle if the pipes were off?
Also.. you can get an idea if you are actually getting fuel pressure by squeezing the fuel feed line after the filter. If it feels tight.. you have fuel pressure. That should be enough to atleast know if you are getting pressure to prime the fuel lines. It wouldn't hurt if you tested the fuel pressure anyway.
Do things in steps. ruling out each possible cause at a time. Using a "flowchart" in your mind
_________________________________________________________________________
~~~ Sig starts below ~~~
MySpace for those who have em'
AIM:Shawn300zxTT
-1997 Acura 2.2 CL, 5spd. Daily Driver.. great little car!
