TwinTurbo.NET: Nissan 300ZX forum - DS door lock issue, broken piece found, NE1 know its' part #
Subject DS door lock issue, broken piece found, NE1 know its' part #
Posted by Sweep on October 23, 2011 at 8:30 PM
  This message has been viewed 355 times.
Message My driver side key lock started rotating nearly 100 degrees and would no longer unlock the door. I investigated further while replacing a window motor today and found this.
Here it is fallen slightly out of place and you can see the top half is missing. You can see where it is supposed to live on the shaft above.
Here is the piece removed.
I see the part 80512HE on Courtesyparts.com that is listed as the rod holder. For $2.99 I'm betting it's only the pivoting part that snaps in and actually holds the rod. The other portion rotates as your turn the key to unlock the door and has an embedded magnet in it.
Have any of you had to replace this before or by chance know what it is?
Thanks in advance!
Regards
Sweep
