TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Are you still using the stock boost solenoids?
Subject Re: Re: Are you still using the stock boost solenoids?
Posted by sandmanz32 on October 22, 2011 at 10:57 PM
  This message has been viewed 111 times.
In Reply To Re: Are you still using the stock boost solenoids? posted by VERTTZ on October 22, 2011 at 10:28 PM
Message What are your actual wastgate actuator arms set for? You could remove the ebc and run a line from the actuator to the plenum and see what you boost. Should be close to what the actuators are set for or "stock" boost on your ebc. If you hit "stock" boost consistantly and hold it, somethings wrong with your ebc, or the install. If you still have trouble reaching the set boost, check for leaks. Its so hard to diagnose cars without being able to drive them, but thats what id start with.
......And just as they're about to catch me.....Twin......Turbos......Kick.......In!
