TwinTurbo.NET: Nissan 300ZX forum - Re: Did you do a boost leak test?
Subject Re: Did you do a boost leak test?
Posted by VERTTZ on October 22, 2011 at 9:57 PM
  This message has been viewed 154 times.
In Reply To Did you do a boost leak test? (n/m) posted by KongZTT GT28RS MD on October 22, 2011 at 09:48 PM
Message No But I do not think there are any leaks. We found 1 leak by the intercooler where I had tried using a stock coupler with a stillen intercooler and the stock coupler was a little short. So we cut the stock coupler in two and added a hard pipe in.
Also turbo response is very quick. If there is a leak it is a very very small one. Pushing in the gas about a 1/2 to and inch and you are already building boost.
It spools very quick to 10.9 with a gain of 10 in manual it just doesnt go over that for some reason even if I stay in the pedal. Now if I pull over to the side of the rode right after doing that,switch the controller to auto and set the gain to 50 and the boost to 18, it spools to 18psi. Also another thing I noticed is usually it will spike around .5 psi on initial spool up and right when it hits say 18.5 the controller drops the boost to 17.5 and runs 17.5 from 4k-7k. Its almost like the controller doesn't know how to control it or maybe one of the solenoids is stuck closed or something?
