TwinTurbo.NET: Nissan 300ZX forum - If the gas came back out of the filler..
Subject If the gas came back out of the filler..
Posted by KongZTT GT28RS MD on October 20, 2011 at 6:13 PM
  This message has been viewed 115 times.
In Reply To 91 tt needs work after sitting for three years. (Kinda Long posted by traderwazz on October 20, 2011 at 01:09 AM
Message You can either have a clog (mouse nest or similar)..
or your carbon canister and lines may be clogged.. It will cause the pressure from the gasoline fuel to push the gasoline back out where you fill it.
I would delete the carbon canister and drain your tank.. who knows.. it could be full of water for some reason.
Listen for your pump to prime the fuel pressure and also check for fuel pressure itself.
Probably wouldn't be a bad idea to remove your pump and check the filter sock.. could be clogged up with gunk.. but if you check what the fuel pressure is.. it will kind of narrow it down
_________________________________________________________________________
~~~ Sig starts below ~~~
MySpace for those who have em'
AIM:Shawn300zxTT
-1997 Acura 2.2 CL, 5spd. Daily Driver.. great little car!
