TwinTurbo.NET: Nissan 300ZX forum - Check your fuel hardlines for dents
Subject Check your fuel hardlines for dents
Posted by ZiNnYc on October 15, 2011 at 2:17 PM
  This message has been viewed 178 times.
In Reply To Misfire woes! posted by Russell.DiVittorio on October 15, 2011 at 02:00 PM
Message Your profile indicates you are a mechanic, so get the car on a lift and check the undercarriage. Key areas: o2 sensors, hard lines, PS solenoid, wiring from tranny. Check your injectors as well.
Common sense and logic says that the boulder had something to do with your issues if you had these symptoms immediately after.
And turn down your boost before you blow your motor. You don't want to run excessively lean from lack of fuel if I'm right.
