TwinTurbo.NET: Nissan 300ZX forum - Re: I would get a look at the plug.
Subject Re: I would get a look at the plug.
Posted by Stadsport (PHX) on October 13, 2011 at 5:01 PM
  This message has been viewed 172 times.
In Reply To I would get a look at the plug. posted by Draker (Eugene, OR) on October 13, 2011 at 04:50 PM
Message I did spray some PB blaster down there, so I'll try again when I get a chance and the engine is warm.
I performed DVDBURN's switched power injector mod a while back, so now that I'm looking at the wiring diagram, I believe the 1000 ohm-from-harness thing is a bit of a red herring on my 5-cylinder problem. It seems that it would be impossible to ohm test through the harness with this mod without the key switch ON and battery hooked up, but it would be impossible then because the multimeter would see voltage and just give me the finger. I may temporarily reverse this mod just for the sake of testing the injectors through the harness.
