TwinTurbo.NET: Nissan 300ZX forum - my intake doesnt have any comunication with the crank
Subject my intake doesnt have any comunication with the crank
Posted by Xteam300TT (South Tx ) on October 12, 2011 at 11:38 AM
  This message has been viewed 202 times.
In Reply To I have a tip,.. do NOT go to 20lbs on a boost leak test... posted by CoHPhasor on October 12, 2011 at 12:29 AM
Message case . Full pcv delete , only vents to catch cans and solid 3" intakes from filters to turbos, portless. It's safe for what I have set up but you are correct , under normal operations and an oem set up you should not gm above 5 psi on a boost leak test .
