TwinTurbo.NET: Nissan 300ZX forum - I checked the timing from all the usual places with
Xteam300TT (South Tx )
on October 11, 2011 at 11:20 PM
Where did you check timing, ptu or coil pack? (n/m)
posted by jlag
on October 11, 2011 at 11:16 PM
varying numbers so I used a high tension wire straight into coil pack #1 to the #1 spark plug . I even flipped the timing light connection 180 and had the same reading .
So after 45min with this lil hottie lastnite we headed back
22:07:45 10/11/11
Swap the connection points on your boost gauges,
BoneZ (MD)
22:40:02 10/11/11
Are you sure you've burped all the air out of the cooling
jlag
22:49:34 10/11/11
I did burp it several times and now the coolant level
22:58:20 10/11/11
I was thinking @ idle I should be pulling more than 20
22:54:07 10/11/11
Re: install your temp sending unit in the lower hose.
tognot
22:41:48 10/11/11
On this point, it would be interesting to compare what .
Boosted1
06:20:50 10/12/11
Well....
1badz32 (MN)
22:49:13 10/11/11
I havent done a compression test yet . I guess that
23:02:29 10/11/11
Note : my tranny cooler is mounted a 1/2" behind the
23:16:37 10/11/11
Even if the E-fan runs 100% of the time, it's still not a
1badz32 (MN)
01:14:48 10/12/11
I have a very similiar setup except I have Ash Massives
ae300z
23:08:31 10/11/11
Not if the car is over heating at idle.
1badz32 (MN)
01:11:04 10/12/11
Stunning Build, congrats! I agree with Allen
TTZEDHEAD
06:46:30 10/12/11
jlag
23:16:24 10/11/11
I checked the timing from all the usual places with -
23:20:22 10/11/11
CAS adjustment
ltd
23:54:26 10/11/11
How is your fan clutch ?
ArubaDave
00:04:31 10/12/11
..I wouldn't. (n/m)
90GoldZ
00:30:42 10/12/11
Me neither... (n/m)
1badz32 (MN)
01:13:17 10/12/11
He means " make sure I dont have an NA clutch on now " (n/m)
18:40:20 10/12/11
Replaced the fan but not the clutch . Is there a
11:30:47 10/12/11
yes
ArubaDave
14:41:44 10/12/11
Thanx , Ill check that out . (n/m)
18:37:02 10/12/11
I have a tip,.. do NOT go to 20lbs on a boost leak test...
CoHPhasor
00:29:22 10/12/11
my intake doesnt have any comunication with the crank
11:38:54 10/12/11
I think you should investigate proper timing even more
Polish
01:11:30 10/12/11
My timing was set using a spark plug wire in coilpack#1 (n/m)
11:27:37 10/12/11
I'll bet you have high ect readings.....
TTZ2NV(TX)
05:46:04 10/12/11
Have you checked the AC condensor to make sure its clear
SkiFly01
10:21:00 10/12/11
condenser fins cleaned during rebuild and no splash shields (n/m)
11:33:28 10/12/11
I recently removed an E-fan setup for the same issue.
SkiFly01
12:59:19 10/12/11
I an running the oem clutch fan and shroud . The efan
15:56:21 10/12/11
sounds like the IC and Trans Cooler are blocking airflow. (n/m)
SkiFly01
11:08:04 10/13/11
I never had any issues with my FMIC (n/m)
KongZTT GT28RS MD
21:52:27 10/13/11
you need splash sheilds
aliaZ
08:57:38 10/14/11
Try putting the belly pans back on. You may find that they
kkrofft (OH)
13:15:02 10/12/11
Thought that autos needed 25* btdc at idle...
bbsalexaz
13:16:25 10/12/11
