TwinTurbo.NET: Nissan 300ZX forum - Stunning Build, congrats! I agree with Allen
Subject Stunning Build, congrats! I agree with Allen
Posted by TTZEDHEAD on October 12, 2011 at 6:46 AM
  This message has been viewed 155 times.
In Reply To I have a very similiar setup except I have Ash Massives posted by ae300z on October 11, 2011 at 11:08 PM
Message You should consider mounting the Tranny cooler in the rear to increase flow through the radiator.
I also have the same upper WT sensor and I believe it reads a little warmer in that location (not a bad thing) additionally I had high engine temps during break in. I replaced the fan clutch, all is well.
Woody has a post regarding the position of your CAS and may give some insight to why its clocked to the far left (search owns me)
If and when I ever build another engine I will DEFINATELY use the hard break in method. IMHO If done properly it decreases blow-by significantly. Not likely that your WBs will ever read identicle (lots of variables and info on this) That said This is the set-up I'll be using as well.
Dyno tune the car imediately! and get those AFRs straightened out.
Gotta....Have....More.....Boost!!!!!!
