TwinTurbo.NET: Nissan 300ZX forum - Check the brake light switch on the brake pedal. First make
Subject Check the brake light switch on the brake pedal. First make
Posted by jmt-z on October 12, 2011 at 1:38 PM
  This message has been viewed 262 times.
In Reply To brake light stuck posted by GitNMyBelly on October 12, 2011 at 01:17 PM
Message sure your pedal isnt depressing it, if so then adjust it. If not then unplug it and see if that turns off your lights. If so then the switch is most likely bad.
[ http://www.300zx-twinturbo.com/cgi-bin/manual.cgi?list=br&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=6&design=default&total=56 ]
"If everything seems under control, you're just not going
fast enough."
- Mario Andretti
