TwinTurbo.NET: Nissan 300ZX forum - Here's everything that's been checked...
Subject Here's everything that's been checked...
Posted by Stadsport (PHX) on October 11, 2011 at 4:41 PM
  This message has been viewed 190 times.
In Reply To My car wont start. posted by spdy2+2 on October 11, 2011 at 04:31 PM
Message -Spun CAS, injectors clicked.
-Used a timing light w/ inductive pickup through a high-tension wire to verify spark while spinning CAS
-Checked PTU connectors, they were fine. Wiring harness is new.
-Swapped FPR
-Swapped fuel pumps
-Ran codes
-Tried disconnecting the MAF
-Swapped ECUs (but kept the EPROM with the car)
A few things to point out:
-It will crank all day, just won't fire. You might here one combustion every 10 cranks, but it doesn't even come close to firing up.
-Fuel pump audibly primes and can be heard running while cranking.
-When removing fuel pump, there was very little pressure in the lines.
