TwinTurbo.NET: Nissan 300ZX forum - Any write ups on replacing the A/C clutch only?
Sweep
on October 11, 2011 at 9:37 AM
Mine is blowing the 10A fuse anytime you try to turn it on. Relay tests fine, betting it is the clutch. Would love to see a tech doc on procedure.
Thanks!
Regards
Sweep
Any write ups on replacing the A/C clutch only? -
Sweep
09:37:51 10/11/11
This is outlined in the FSM.
Draker (Eugene, OR)
10:48:41 10/11/11
Thanks, I loaned mine and it has been misplaced, I'm fairly
Sweep
10:53:22 10/11/11
Here
Draker (Eugene, OR)
12:31:42 10/11/11
Thanks a TON, on both posts! (n/m)
Sweep
14:49:04 10/11/11
Can clutch be replaced with compressor on the car, or does
Sweep
10:58:45 10/11/11
It should be okay to do it on the car.
Draker (Eugene, OR)
12:29:55 10/11/11
