TwinTurbo.NET: Nissan 300ZX forum - Connect bettery and blow the battery fuse...
Subject Connect bettery and blow the battery fuse...
Posted by akdawgg99 on October 10, 2011 at 12:30 AM
  This message has been viewed 311 times.
Message Just finished my build and went to connect the battery. As soon as it is hooked up it sparks at the negative terminal and then the battery fuse fizzles, smokes and blows.
Am I forgetting a ground somewhere or did I screw something up when plugging in the harness?
EGR, AVI, PRVR (or whatever it is) is all deleted and connectors were just left unplugged with no resistors in them, for now.
Chassis harness was swapped out, because my original was all spliced and hacked. Everything hooked up clean and all grounds were connected as far as I know.
What can be causing it to short?
