TwinTurbo.NET: Nissan 300ZX forum - STock OP gauge is lower than actual.
Subject STock OP gauge is lower than actual.
Posted by Gordo 93TT Daytona on October 09, 2011 at 8:15 PM
  This message has been viewed 100 times.
In Reply To Acceptable oil pressure? posted by dutch_Z on October 09, 2011 at 04:11 PM
Message Some engines might show 60 psi on startup. Mines about 50 psi and settles down to about 30 at idle. Cruise is somewhere in between.
If your gauge is like most, the readings you note are acceptable and OK. You can buy an aftermarket gauge and wire it into a second sender unit plumbed into a T at the oil filter junction.
_________________________________________________
