TwinTurbo.NET: Nissan 300ZX forum - Do you feel the petal pressure building up on its own
Subject Do you feel the petal pressure building up on its own
Posted by Bo (Houston) on October 08, 2011 at 1:55 PM
  This message has been viewed 105 times.
In Reply To Re: Cluch problems Please help (n/m) posted by jabook150 on October 08, 2011 at 12:00 PM
Message when you're sitting at a light or when the engine temp goes up? If so, for that specific problem, there are 3 things it could be. You may need to adjust the master cylinder (petal play) so that the extra pressure is able to go back into the master cylinder instead of pushing on the slave. You may need to vacuum bleed to get all the air out. Or you could have a dislodged disk inside the brake booster.
