TwinTurbo.NET: Nissan 300ZX forum - Was the water 190 degrees? (n/m)
Draker (Eugene, OR)
on October 07, 2011 at 12:40 PM
Bad news...I pressure tested the fuel rail to 70psi under
posted by Wright (Ca)
on October 07, 2011 at 12:30 AM
Should fuel pressure hold after shutting off a hot engine?
Wright (Ca)
12:00:58 10/06/11
Re: Should fuel pressure hold after shutting off a hot engine?
Bo (Houston)
12:28:23 10/06/11
It is not normal for the fuel pressure to drop but it is
treese88
12:42:45 10/06/11
Both vac lines are dry. I appreciate the help. I suspect a
Wright (Ca)
12:54:34 10/06/11
Take a good look at your injector orings too. (n/m)
Bo (Houston)
13:07:47 10/06/11
Will do. First things first, I need to see if I can get the
Wright (Ca)
13:54:39 10/06/11
I am starting to wonder if I have this issue also.
Draker (Eugene, OR)
13:19:42 10/06/11
Wright (Ca)
00:30:05 10/07/11
Was the water 190 degrees? (n/m) -
Draker (Eugene, OR)
12:40:45 10/07/11
No. 120 maybe. You think I should try again at higher temp?
Wright (Ca)
13:44:28 10/07/11
There is a chance.. but if you are pulling the motor..
Draker (Eugene, OR)
18:58:51 10/07/11
