TwinTurbo.NET: Nissan 300ZX forum - Re: Should fuel pressure hold after shutting off a hot engine?
Subject Re: Should fuel pressure hold after shutting off a hot engine?
Posted by Bo (Houston) on October 06, 2011 at 12:28 PM
  This message has been viewed 216 times.
In Reply To Should fuel pressure hold after shutting off a hot engine? posted by Wright (Ca) on October 06, 2011 at 12:00 PM
Message It's normal for the fuel pressure to go down to 0 overnight, but if you pinched the return line and feed line the pressure should hold indefinitely. I can't see it going all the way down to zero just because the gas cooled off. On a hot engine I've pinched the return and feed line and the pressure held for hours. I took it off because the pressure wasn't going down.
