TwinTurbo.NET: Nissan 300ZX forum - Found the cause of the constant run Aux fan!
Subject Found the cause of the constant run Aux fan!
Posted by Jayru on October 06, 2011 at 10:13 AM
  This message has been viewed 132 times.
In Reply To Temp sensor Ohm's are in spec posted by Jayru on October 04, 2011 at 12:15 PM
Message Went through the diagnosis steps in the FAQ - ruled out the temp sensor & found my way to the relay. The PO put a jumper wire in the large fuse box on the DS that shorts the fan relay to ground causing it to run constant. Disconected the ground wire & the fan turned off!
Now I just need to figure out what they spliced because the fan doesn't work at all with the ground short disconnected. Taking apart the bottom of the fuse box today to find out.
(Previous Z's - 92 TT stage I - 94 TT stage III)
Current Z - 90 TT stage IV - being rebuilt
