TwinTurbo.NET: Nissan 300ZX forum - My fuel pressure drops but it doesn't affect idle. Based
Subject My fuel pressure drops but it doesn't affect idle. Based
Posted by treese88 on October 05, 2011 at 11:12 AM
  This message has been viewed 317 times.
In Reply To Re: Wandering AFR at idle and hesitation under WOT. posted by WazTTed on October 04, 2011 at 03:58 PM
Message on the fact that your system just recently started dropping pressure it is probably related. Clamp off just after the fuel filter/before pressure sensor. Then clamp off the return line. Leave it over night. If pressure still drops then your fuel leak is either injectors, regulator, or dampener.
Otherwise the system can lose pressure at the pump which doesn't really affect anything.
Good luck.
'91 TT
