TwinTurbo.NET: Nissan 300ZX forum - Are you using a stock or aftermarket regulator? (n/m)
Woody75 (Denver)
on October 05, 2011 at 9:01 AM
So I left the fuel pressure gauge hooked up over
posted by Wright (Ca)
on October 04, 2011 at 09:05 AM
Wandering AFR at idle and hesitation under WOT.
Wright (Ca)
20:50:41 10/03/11
check the MAFS signal voltage (n/m)
sandmanz32
21:09:45 10/03/11
Re: Wandering AFR at idle and hesitation under WOT.
sandmanz32
21:12:56 10/03/11
I have selin elbows but use a apexi neo to average the
Wright (Ca)
21:52:00 10/03/11
Cloosed loop or open at idle? (n/m)
Wright (Ca)
08:25:40 10/04/11
open loop at idle (n/m)
sandmanz32
18:27:39 10/04/11
Wright (Ca)
09:05:19 10/04/11
Are you using a stock or aftermarket regulator? (n/m) -
Woody75 (Denver)
09:01:19 10/05/11
Stock. I installed new reg/dampener/filter a few thousand
Wright (Ca)
10:55:54 10/05/11
WazTTed
15:58:32 10/04/11
Thanks. I did this test years ago and thought I remembered
Wright (Ca)
16:07:34 10/04/11
yea, i second that. get your fuel leak buttoned down
sandmanz32
17:49:21 10/04/11
My fuel pressure drops but it doesn't affect idle. Based
treese88
11:12:36 10/05/11
What do you use to clamp the line off with? Seems
Wright (Ca)
11:48:18 10/05/11
Vice grips with quarters on the clamping part to create a
treese88
09:06:04 10/06/11
