TwinTurbo.NET: Nissan 300ZX forum - Stalling problem update. I disconnected the MAF and the
Subject Stalling problem update. I disconnected the MAF and the
Posted by DARK KNIGHT on October 03, 2011 at 2:50 PM
  This message has been viewed 199 times.
Message DOES NOT stall. with the car running, I CONNECT the MAF and the car stalls out.
The Datascan tells me, Air Flow reading is good:
with MAF connected and car started
1. I use throttle cable to keep car from stalling (at 1,000 rpms) and Air Flow voltage is 1.34 on Datascan.
2. At 2,000 rpms, Air Flow voltage is 1.55v (good)
But with multimeter and voltages checked at MAF connector harnes (as per the FSM):
1. ACC switch "ON", engine stopped and car fully warmed. voltage is .3 (BAD)
