TwinTurbo.NET: Nissan 300ZX forum - If so.. I had a similar problem on my NA..
Subject If so.. I had a similar problem on my NA..
Posted by KongZTT GT28RS MD on October 02, 2011 at 1:26 PM
  This message has been viewed 109 times.
In Reply To When you start it... does it idle higher than normal? posted by KongZTT GT28RS MD on September 30, 2011 at 09:35 PM
That is on the main auto trans harness.. It runs up to the Inner fender well.
There is a brown connector (the bigger of the connectors) that is on the main transmission harness on the inner fenderwell. There is an internal rectangle rubber o-ring caused it not to correctly seat itself. It caused that 16 flashes like you mention and for the trans to be in limp mode.
Check that first.
If not.. there is a brown (w/yellow stripe I believe) wire (TPS circuit).. that runs to transmission. Mine touched exhaust manifold and caused it to short out).
_________________________________________________________________________
~~~ Sig starts below ~~~
MySpace for those who have em'
AIM:Shawn300zxTT
-1997 Acura 2.2 CL, 5spd. Daily Driver.. great little car!
