TwinTurbo.NET: Nissan 300ZX forum - Re: Need help with - AVCR set up with external wastegates plumbi
Subject Re: Need help with - AVCR set up with external wastegates plumbi
Posted by Stadsport (PHX) on September 29, 2011 at 12:57 PM
  This message has been viewed 400 times.
In Reply To Need help with - AVCR set up with external wastegates plumbi posted by 2ZXTRM on September 29, 2011 at 12:46 PM
Message If you're using external wastegates, you need to use the NC port, not the NO port. The setups should otherwise be pretty much identical:
The differences being that the green line should run from the "to throttle body" pipe to the NC port instead of the NO port, and of course the wastegates are external and not actuator types.
The setup described in the AVC-R manual is accurate. If you're having trouble boosting past 16psi, but can otherwise control the boost, I would look elsewhere for reasons (wastegate spring pressure, boost leaks, etc).
