TwinTurbo.NET: Nissan 300ZX forum - Need help with - AVCR set up with external wastegates plumbi
Subject Need help with - AVCR set up with external wastegates plumbi
Posted by 2ZXTRM on September 29, 2011 at 12:46 PM
  This message has been viewed 497 times.
Message Assistance please
Need help with - AVCR set up with external wastegates plumbing please.
Too many conflicting result found on the net with no defining answer.
The Apexi manual shows set up as thus using the (NC) port.
Option-1
I originally had it configured as this all plumbed up, but couldn't boost over 16PSI.
note pressure is connected to - (NO) port.
Option-2
My tuner changed it to this, and managed to get it to go to 19PSI - but no higher no matter what was dialled into the AVCR controller.
still - note pressure is connected to - (NO) port.
Option-3
So can the Zed Gurus please tell me which is the best option to have this set up.
I think I may have to start playing with the wastegate spring pressures and adjustments.
Note I have stronger springs installed but the adjustment screw is only about halfway wound in.
Also this is for the old skool - Greedy TD05 setup - if that helps.
Any information will be greatly Appreciated.
Thanks.
