TwinTurbo.NET: Nissan 300ZX forum - Oil smell/Exhaust smoke after new turbos
Subject Oil smell/Exhaust smoke after new turbos
Posted by atomatiX on September 28, 2011 at 7:36 AM
  This message has been viewed 734 times.
Message '90 TT 300zx 180k miles. I recently had the engine pulled because of my passenger side turbo failing, causing the exhaust to smoke heavily from oil.
List of mods/work done:
turbos swapped (GT600R kit)
AMS manifolds
z1 2.5" downpipes
550cc JECS injectors
'95 Harness
New style CAS(to fit '95 harness)
z1 2.5" testpipes
Greddy Profec Spec 2
z1 Clutch + flywheel combo (550 ft/lb)
dual intake
z1 ECU CHIP(dual, 555cc, 93 octane(only 92 octane available, timing will be changed, although not changed yet)
Most oil/water lines replaced
Compression tested at 165 ±5 all across the board.
CAR HAS NOT BEEN TUNED YET (besides new ecu chip)
Whenever I start the car and leave it running for a bit, I begin to smell oil. If I drive it around/boost around a bit, I smell more of the oil and I can visibly see smoke coming from exhaust.
I am hoping it is just leftover oil burning off, but this is the fourth time starting the car. I have only driven it about 2 miles.
Should I keep driving, hoping that it will go away? Or would it be a different problem... :(
  • Oil smell/Exhaust smoke after new turbos - atomatiX 07:36:04 09/28/11
