TwinTurbo.NET: Nissan 300ZX forum - Re: Re: CAS question
Subject Re: Re: CAS question
Posted by Markzxj on September 27, 2011 at 7:39 PM
  This message has been viewed 127 times.
In Reply To Re: CAS question posted by Stadsport (PHX) on September 27, 2011 at 06:18 PM
Message Thanks for the response. I do have the CAS installed already and it is lined up correctly. The drive pin is still attached to the cam, it is just that little alignment dowl that is broken off. The splines don't seem to be worn, do you think I will be ok or will my timing still wander? Do you have any more info on how you installed the new alignment tab with an old CAS? Thanks!
