TwinTurbo.NET: Nissan 300ZX forum - Trying to diag low compression and weird noise *vid inside
Subject Trying to diag low compression and weird noise *vid inside
Posted by robomatic12 on September 25, 2011 at 12:33 PM
  This message has been viewed 159 times.
Message After taking my Z to the local drag strip I noticed a strange misfire at idle which after checking everything out led me to low compression in the #6 cylinder with 90psi. Every other cylinder has 150psi. The engine was rebuilt 10,000kms ago.
There is also this weird rattling noise only at first throttle but sounds higher up in the engine. I've been told it might be a stuck lifter or a broken valve spring. I'm hoping this is causing the low compression.
http://www.youtube.com/watch?v=dCvHFeT9DfM...be_gdata_player
