TwinTurbo.NET: Nissan 300ZX forum - Ok, I'll double check
_biz_
on September 22, 2011 at 10:18 AM
They have the same plug. Its a common made mistake. (n/m)
posted by Woody75 (Denver)
on September 22, 2011 at 09:57 AM
Pardon my ignorance but could you confirm which connector, or where the wires are coming from, for the VTC? I just want to be sure I know what I'm looking at when confirming that.
Thanks!
stuck in safety boost after injector replacement
_biz_
20:41:42 09/21/11
Should not be related to the injector change
SilverTwin(OH)
06:35:38 09/22/11
Re: Should not be related to the injector change
_biz_
07:12:55 09/22/11
Run the diagnostic at the ecu
SilverTwin(OH)
07:57:04 09/22/11
Yep, code 34
_biz_
08:39:52 09/22/11
Re: Yep, code 34
_biz_
08:57:23 09/22/11
It was 55, but by the time I checked it at work it was 34
_biz_
09:44:30 09/22/11
How did you change the injectors? Remove plenum?
Woody75 (Denver)
07:38:10 09/22/11
Re: How did you change the injectors? Remove plenum?
_biz_
07:46:46 09/22/11
They fit together, might be that simple.
jdubs
09:17:44 09/22/11
Really? I could only find one harness ...
_biz_
09:41:35 09/22/11
Woody75 (Denver)
09:57:28 09/22/11
Ok, I'll double check -
_biz_
10:18:52 09/22/11
What I recall is that there are three harnesses right there
_biz_
10:20:19 09/22/11
Actually doing fast research
_biz_
10:22:12 09/22/11
VTC + Det sensor harnesses were crisscrossed
_biz_
10:44:21 09/22/11
Cool beans. It's common. No biggy. (n/m)
Woody75 (Denver)
11:26:53 09/22/11
