TwinTurbo.NET: Nissan 300ZX forum - stuck in safety boost after injector replacement
Subject stuck in safety boost after injector replacement
Posted by _biz_ on September 21, 2011 at 8:41 PM
  This message has been viewed 169 times.
Message I upgraded my injectors to the Nismo 615cc. I replaced the stock injectors and upgraded the eprom.
Largely things are fine but it appears I'm in safety boost (only boosting to 6psi). I am running the colder burning plugs. I have not replaced the fuel filter yet but if that does not work I will try to retard the timing to see if I cannot get the car to boost back to the expected 13.5 psi.
My question is; is it common to run into these sorts of issues when going from stock injectors to after market higher performance ones? Is there something I could have overlooked in the process?
The car actually sat for a year during the time the injectors were going to be replaced. I also wonder if the fuel being that old and also containing injector cleaner from before I started this upgrade, could be causing detonation. Perhaps I could put in some octane booster.
Is my logic/approach good thus far?
Thanks!
