TwinTurbo.NET: Nissan 300ZX forum - Re: I would set the TPS to .45V and find the real issue.
Subject Re: I would set the TPS to .45V and find the real issue.
Posted by KA8 on September 21, 2011 at 3:47 PM
  This message has been viewed 136 times.
In Reply To I would set the TPS to .45V and find the real issue. posted by Draker (Eugene, OR) on September 21, 2011 at 11:20 AM
Message Thanks for the help. Looks like I need to put in some time which I don't have right now. Just one quick question. So if I adjust the tps at .45V the idle is at 1500rpm or so. I don't think i have a vacuum leak because when I replaced injectors I retightened all hoses and used new seals including plenum seals. I know how vacuum leak feels like because I had fluctuating idle but it went away after new injectors/seals. The IACV was cleaned 10K miles ago. Will having bad timing cause high idle like mine does?
