TwinTurbo.NET: Nissan 300ZX forum - Re: Stalling at idle and slight hesitation. LOW IDLE
Subject Re: Stalling at idle and slight hesitation. LOW IDLE
Posted by Stadsport (PHX) on September 21, 2011 at 12:01 PM
  This message has been viewed 196 times.
In Reply To Stalling at idle and slight hesitation. LOW IDLE posted by DARK KNIGHT on September 20, 2011 at 02:07 PM
Message "-disconnected the yellow femal connector on the IACV to set idle/rpm (750 +/-50) with idle screw but the rpm did not change. I turned fully CW and CCW and no change in idle/rpm (confirmed)."
If you're able to turn the screw in all the way and not see a change in idle, you have a vacuum leak. Plus, a vacuum leak would cause stalling at idle and maybe even slight hesitation.
