TwinTurbo.NET: Nissan 300ZX forum - Also check your fan clutch. Try spinning it by hand
Subject Also check your fan clutch. Try spinning it by hand
Posted by treese88 on September 21, 2011 at 10:10 AM
  This message has been viewed 84 times.
In Reply To Yeah, I'll check the boost controller posted by ZnMyHead on September 20, 2011 at 05:28 PM
Message It should have a fair amount of resistance but shouldn't be frozen in place or spin easily.
Very strange problem with the boosting. While you are checking for leaks and the boost controller I would also do a power balance test by pulling the coil pack connectors one at a time. Then I would also ohm each of your injectors (should be around 10-14 ohms I believe).
'91 TT
