TwinTurbo.NET: Nissan 300ZX forum - Yeah, I'll check the boost controller
ZnMyHead
on September 20, 2011 at 5:28 PM
so at full throttle you only see 5 psi unless you
posted by Supermario680 (WI)
on September 20, 2011 at 02:56 PM
there may be some way I could have the lines backwards I suppose, I'll let you know.
Any idea about the loud roar from the engine bay, sounds like a huge fan pushing alot of air
5psi boost
ZnMyHead
13:47:00 09/19/11
Boost leak test (n/m)
Supermario680 (WI)
15:33:26 09/19/11
Blipping the throttle tells me you are in neutral. You
treese88
15:41:44 09/19/11
no I'm not in neutral
ZnMyHead
03:25:09 09/20/11
Supermario680 (WI)
14:56:39 09/20/11
Yeah, I'll check the boost controller -
ZnMyHead
17:28:50 09/20/11
check to see if your ac condensor fan is running, could have
Red Hawk (CO)
22:10:01 09/20/11
Also check your fan clutch. Try spinning it by hand
treese88
10:10:17 09/21/11
