TwinTurbo.NET: Nissan 300ZX forum - TPS and MAF are right on according to the Blazt software
Subject TPS and MAF are right on according to the Blazt software
Posted by DARK KNIGHT on September 20, 2011 at 4:49 PM
  This message has been viewed 118 times.
In Reply To Have you checked the compression? have you checked posted by Supermario680 (WI) on September 20, 2011 at 02:50 PM
Message I had a previous problem this past May-June and checked compression, it was fine then.
today i checked:
-The spark plug for cylinider #4, spark plug is "ok" (correct fouling), the coil pack resistance reads like coil pack #1 (cylinder is fine).
-Removed the IACV/AAC vavle to really spray it with WD-40 and test it with a 9v battery---GOOD (click on both solenoids)
-Only sprayed into the air regulator unit with WD-40 on both sides of the house tube inlets.
Do you think clogged PCV Valves could cause it?
O2 sensors? on the Blazt software, they should sweep (fluctuate the span of the guage). They have before, now it doesn't. it has a steady reading value.
