TwinTurbo.NET: Nissan 300ZX forum - Stalling at idle and slight hesitation. LOW IDLE
Subject Stalling at idle and slight hesitation. LOW IDLE
Posted by DARK KNIGHT on September 20, 2011 at 2:07 PM
  This message has been viewed 406 times.
Message the stalling has gotten worse over the past week.
cold/warm enigne same stalling/hesitation. (NO hunting or high idle)
The IAVC/AAC, air regulator, spark plugs, injectors (nismo 555), wiring harness, CAS, basically everything from a rebuild are less than a year old.
the rebuild was done almost a year ago and car ran fine.
just recently the syptoms started showing themselves.
I connected Nissan Data Scan from Blazt (can send files of idle if you want).
What I have done:
-I checked the common connectors for corrosion (all were good since new harnes and sensors were installed at rebuild).
-Vacuum boost leak test. I hear air from driver side, can't pinpoint if it is the side of the engine (turbo solenoid or wastegate on turbo) or at back of engine (driver side).
-IACV/AAC & air regulator WD-40 cleaning (did not take apart) units were new. just sprayed WD-40 into the tubes several times (it seems to have gottem better but still hesitates but didn't stall)
***had the Blazt connected to monitor and set idle/rpm***
-disconnected the yellow femal connector on the IACV to set idle/rpm (750 +/-50) with idle screw but the rpm did not change. I turned fully CW and CCW and no change in idle/rpm (confirmed).
-reconnected IAVC yellow femal connector and adjusted idle screw and noticed some change in idle.
-ran ecu codes: 55 No faluts codes
***other important things****
-using the blazt, i turned on/off each spark plug noticed idle/rpm drop on all plugs except #4.
-battery good
-alternator good
-checked injectors about a month ago all read 12-14 ohms (good)
-fuel fileter less than a year old
-i have the dreaded bealt noise on cold start up
-2 days ago, while parking, felt like the power steering did not work. could be because the idle/rpms were low.
Any ideas would be greatly appreciated!
I'm in west palm beach, Fl. here is my email and number: 561-301-9829 darkml@hotmail.net
Thanks
