TwinTurbo.NET: Nissan 300ZX forum - no I'm not in neutral
Subject no I'm not in neutral
Posted by ZnMyHead on September 20, 2011 at 3:25 AM
  This message has been viewed 73 times.
In Reply To Blipping the throttle tells me you are in neutral. You posted by treese88 on September 19, 2011 at 03:41 PM
Message This is driving normal under load, if I shift and apply gas pedal in smooth motion the pressure maxes out at 5psi, if I give a little gas let off give a bit more again, repeat and continue into higher rpms this is when I see 12 psi.
Sorry for any confusion,
Also I'm hearing a load roar from the engine like the fan or turbos are working over time.
really puzzled with all this
