TwinTurbo.NET: Nissan 300ZX forum - Re: It must be timing issues saturday .. here's mine >>
Subject Re: It must be timing issues saturday .. here's mine >>
Posted by jaidieray on September 18, 2011 at 5:55 PM
  This message has been viewed 75 times.
In Reply To It must be timing issues saturday .. here's mine >> posted by xteam300tt on September 17, 2011 at 02:50 PM
Message [ http://300zx-twinturbo.com/cgi-bin/manual.cgi?list=efec&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=35&design=default&total=190 ]
Get a cheap spark plug wire you dont need and cut one end to expose the "core" wire inside. Leave the metal "prong" side of the wire that grabs onto the sparkplug alone.
Remove your #1 coilpack and stick the sparkplug wire, the exposed wire side up inside it. Connect the other end to #1 spark plug using a screwdriver or whatever to make sure it "snaps" into place on the sparkplug.
Connect timing light pickup to your cheap wire,+to+ -to- ,crank car and thats what your base timing actually is assuming your idle is correct.
90na2tt swap KH2 charcoal 5spd
93tt 5spd AH3=sold 90na auto EJO=sold
06 spec v=sold 95 awd talon=sold
