TwinTurbo.NET: Nissan 300ZX forum - Pulling crank dampener pulley
Subject Pulling crank dampener pulley
Posted by JMartz on September 17, 2011 at 7:29 AM
  This message has been viewed 100 times.
In Reply To Timing Belt Update posted by msb1987 on September 17, 2011 at 12:55 AM
Message Although it might work you don't need a jaw type puller for this job. Clean the threads on the 2 holes in the dampener with a tap and use 2 of the long bolts holding the front cover (remove the ruber wahsers and add some larger washers). Using a standard dampener pulley it comes out easy.
The evaporatior is close so protect it.
