TwinTurbo.NET: Nissan 300ZX forum - Re: You can start with tightening the clamps but the leak
Subject Re: You can start with tightening the clamps but the leak
Posted by TRdave on September 16, 2011 at 3:50 PM
  This message has been viewed 89 times.
In Reply To You can start with tightening the clamps but the leak posted by Dave N on September 16, 2011 at 02:51 PM
Message 23mm bolt on top side. I will tighten and see what happens.
:most likely is coming from the crimped hose assembly (in the upper left of your picture). There could also be a leak from the shaft seal of the pump, but stick with investigating the hoses for now.
:I suggest putting some extra turns on all the clamps and then wiping everything off as much as possible. Then check the area again within a week or so (depending on how much driving you do). This may help you pinpoint the leak.
:Dave
