TwinTurbo.NET: Nissan 300ZX forum - Passenger Window Problem
Subject Passenger Window Problem
Posted by ThreeM on September 13, 2011 at 6:42 PM
  This message has been viewed 177 times.
Message Spent some time searching for someone here that has had a similar problem...found some good info, but still can't figure out the reason my passenger window will not go up.
- passenger window lock is not engaged
- driver's side passenger window switch will not raise the passenger window. Passenger window switch will not raise the passenger window.
- passenger window will go up if I switch the wiring around and cause the window motor to spin the opposite way when pressing down on the passenger or driver's window switch.
- passenger window receives +12V and -12V when the switch is operated without the motor attached, bought a new switch anyway - the old switch looked old!
- passenger window motor operates fine (both ways) when plugged into the driver's side window motor connector
- found the small box near the bottom center of the driver's side door. When unplugged, the passenger window will go down, but not up. The driver's window will not operate.
- do not have a blown fuse
I guess this just leaves a wiring problem somewhere after the driver's side switch and before the passenger window switch. Unless, the small box that I found is bad. Anyway to test the box?
Thanks!
