TwinTurbo.NET: Nissan 300ZX forum - Re: Sure can - one common issue is the hood trigger switch
Subject Re: Sure can - one common issue is the hood trigger switch
Posted by red z 2 b tt on September 12, 2011 at 7:47 PM
  This message has been viewed 159 times.
In Reply To Sure can - one common issue is the hood trigger switch posted by jzack on September 12, 2011 at 07:11 PM
Message :going bad (due to moisture). Just unplug it from the harness connector and see if that fixes the issue? Mine is permanently disconnected and removed to cut down on engine bay clutter.
:Probably a similar issue with the door pin switch too. Try removing and cleaning it. At least with the hood switch eliminated, problem solution is narrowed down...
I did that and its still the same. If all pin switches are unpluged this should fix the problem? If a pin switch is bad unplugging it would trick the car into believing that its closed? How does the pin switch work?
