TwinTurbo.NET: Nissan 300ZX forum - Need some input in swaping a tt fuel pump into a 2+2.
Subject Need some input in swaping a tt fuel pump into a 2+2.
Posted by z32z on September 11, 2011 at 5:29 PM
  This message has been viewed 171 times.
Message I am doing a tt conversion on a 92 2+2. As seen in the picture below the tt fuel pump on the left is a lot longer and allso has 3 wire connectors and 3 fuel line connector. The na has one wire connector, two hose connector, and is a lot shorter. Both pumps have 5 wires leading into the pump alltho the tt pump has more than 5 wires on the outside. I assume the wires are spliced together for the differant connectors.
To install this pump into the 2+2 do I just swap out the pump from one assemble to the other. Allso is there any special things I need to do for the wires. Will the one connector on the 2+2 operate the pump on all 3 stages.
Thanks for your help this is my first TT conversion and its allmost completed in one weewkend.
[IMG]http://i843.photobucket.com/albums/zz353/pjzaner/300zx%20wide%20body/new%20wheels/048.jpg[/IMG]
