TwinTurbo.NET: Nissan 300ZX forum - Re: o2 sensor replacement na
jjamez
on September 10, 2011 at 5:50 PM
posted by jjamez
on September 10, 2011 at 05:16 PM
they look accessable from the top, just need to remove the battery on the passenger side.
oems? bosch? does it matter?
jjamez
17:16:40 09/10/11
I unclip them from up top, the get under the car and remove
Red Hawk (CO)
17:48:45 09/10/11
Re: o2 sensor replacement na -
jjamez
17:50:15 09/10/11
I found them pretty easy to access via the top --
jzack
22:47:35 09/10/11
Re: -
jjamez
23:20:51 09/10/11
IF you can get them removed from the O2 sensor --
jzack
17:16:49 09/11/11
used a little pb blaster, and got mine apart. (n/m)
jjames69
14:00:07 09/12/11
Did that too as well as freezing spray, heat, torch , etc... (n/m)
jzack
19:16:59 09/12/11
OEM is Bosch (n/m)
na300zx (OH)
06:06:43 09/12/11
bosch(o reilly)$180, dealer $250 (n/m)
jjames69
14:05:58 09/12/11
is there only 2 sensors?
jjamez
18:20:51 09/10/11
