TwinTurbo.NET: Nissan 300ZX forum - If you used a JDM motor then check the oil pan.
Subject If you used a JDM motor then check the oil pan.
Posted by JonnyZ(SoCal) on September 09, 2011 at 12:39 PM
  This message has been viewed 137 times.
In Reply To low oil pressure!!!need your help posted by JOZ32 on September 08, 2011 at 04:09 PM
Message If it has a dent like most of them do then it tends to drop the pressure. The clearances between the oil pan and pick up tube are a lil tight. I just pulled my pan a few weeks ago and noticed how bad a few dents can be to the tube. Be sure to test the easy things first. This is just a suggestion :)
