TwinTurbo.NET: Nissan 300ZX forum - i would make sure the pan isnt pushed in blocking
xteam300tt
on September 08, 2011 at 9:35 PM
low oil pressure!!!need your help
posted by JOZ32
on September 08, 2011 at 04:09 PM
the pick up tube . check oil level then the sending unit .
JOZ32
16:09:33 09/08/11
What oil are you using?
MixManMash
17:33:28 09/08/11
Re: What oil are you using?
JOZ32
02:05:05 09/09/11
i would make sure the pan isnt pushed in blocking -
xteam300tt
21:35:38 09/08/11
If you used a JDM motor then check the oil pan.
JonnyZ(SoCal)
12:39:28 09/09/11
Yes I used a JDM engine,the oil pan has few dents
JOZ32
15:22:57 09/09/11
you dont have to pull the pan off . You can bend a screw
xteam300tt
18:36:08 09/09/11
I had the same problem after i did my swap and
Z OLOGY
08:35:35 09/11/11
Re: I had the same problem after i did my swap and
JOZ32
08:53:02 09/11/11
