TwinTurbo.NET: Nissan 300ZX forum - The NA sensor has it's shaft offset to accomodate the larger
Subject The NA sensor has it's shaft offset to accomodate the larger
Posted by Wright (Ca) on September 08, 2011 at 5:26 PM
  This message has been viewed 223 times.
In Reply To Manual Speed Sensor posted by Sleeper_TTZ(SeKy) on September 08, 2011 at 02:17 PM
Message NA pinion gear. You can use either speed sensor as long as you use a TT gear on a TT sensor and NA gear on a NA sensor. The worm shaft within the transmission is same between NA and TT transmissions in size and location.
Formerly: ZEVAN (Ca), Evan3zx(ca)
